2003 Chevy S-10 Wheel hub bearings
46,782 MILES • 4 CYL • 2WD • AUTOMATIC
JIM AUSTIN
What is the reccommended torque
Aug 27, 2010 at 1:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
sealed non greasable bearings would be around 65 ft lbs greaseable bearings are just snug up tight w/channel locks then back off slightly to where the nearest cotter pin hole is to allow for heat and expansion of the bearing assembly
Aug 27, 2010 at 2:37 PM
