Water sloshing sound on passenger side of truck heard at excellartion. A/C works cold air, but I see no codensation or water discharge on ground.
Mar 22, 2010 at 8:36 AM
YAHOO4
MEMBER
the water sound is water rushing through a restricted heater core ,engine cold and off remove both heater hoses on pass side fire wall and take your garden hose and continuosly run water through for about 2 min then reverse flow the opposite direction the same, may need to do this a couple of times until water is clean, then refill cooling system and drive
Apr 30, 2010 at 4:01 PM
