2003 Chevy S-10 Testing for leaks
2003 CHEVROLET S-10
65,000 MILES • 6 CYL • 4WD • MANUAL
BILLMCM41
I just replaced rotors, calipers, & pads on the front end of my truck. I tried to bleed lines but nothing. I then plugged the ports on the master cylinder to see if it was bad. Master seems fine. plugging the back port on the master seems to indicate a bad line.? Question is what line is connected with the back port on the master?
The abs light is still on also
Oct 11, 2010 at 6:07 AM
WRENCHTECH
  • 20,761 POSTS
You probably need to pressure bleed the system at this point. If you let too much fluid drain out, then you get completely air bound.
Before continuing, verify that the bleeders are at the top of the calipers and not the bottom.
Oct 11, 2010 at 6:19 AM
