The rotors are attached to the axle. After the caliper is removed, how do you remove the rotor?
Apr 9, 2010 at 3:39 AM
BLUELIGHTNIN6
✓Experienced Mechanic
once the brake caliper and pads are out of the way then the rotor just slides off..if it seems stuck you will need to jar it loose with a rubber mallet, beating in between lug studs
