2003 Chevy S-10 rear end
53,456 MILES • 6 CYL • 4WD • AUTOMATIC
SCOTTB224
how can you tell which gasket to use other than taking the cover off want to buy gasket before taking it apart so i can put back together without running to the store it has the locking diff in it and 3.73 gears
Sep 1, 2008 at 2:00 PM
SWILLIAMS
  • 597 POSTS
It should have the regular 10 bolt rear cover. It is the same one that was used on the Monza as well.
Sep 6, 2008 at 6:43 AM
BIG S-10 RICK
  • 11 POSTS
[quote:0870a25cad="scottb224"]Suspension problem
2003 Chevy S-10 6 cyl Four Wheel Drive Automatic 53456 miles
how can you tell which gasket to use other than taking the cover off want to buy gasket before taking it apart so i can put back together without running to the store it has the locking diff in it and 3.73 gears[/quote:0870a25cad] i use rockwell auto web sites you can look up repair info.
Sep 9, 2008 at 7:57 AM
