2003 Chevy S-10 ping, stopped while driving
13,500 MILES • 4 CYL • 2WD • MANUAL
RTOTTEN
driving on freeway, heard some pinging noises, and had a sudden loss of power, pulled over and found the radiator to have no fluid, the gages did not indicate a problem. I put fluid in the radiator, it was leaking at as fast as you could put it in. the truck will crank, but will not start. what do you think? problem big or little?
Apr 15, 2008 at 7:45 AM
  • 75,988 POSTS
The engine will detonate/ping if its overheating-find where the leak is then report back.
Apr 15, 2008 at 7:52 AM
RTOTTEN
thanks, The leak is from the engine block, on the spark plug side.
Apr 15, 2008 at 10:37 AM
  • 75,988 POSTS
Reply to PM
A leak there and no compression could mean a blown headgasket.
Apr 16, 2008 at 2:14 AM
