2003 Chevy S-10 overheating
2003 CHEVROLET S-10
JESSE.TYLER.24
  • 6 POSTS
Engine Cooling problem
2003 Chevy S-10 6 cyl Two Wheel Drive Manual 110k miles
I recently flushed (store bought cleaner sytem) the coolant, radiator, and changed the thermostat. After a week the truck started to overheat (220-260 degree fluctuations). I assumed air had built up in the system ; however, I have tried running the engine with the radiator cap off until the thermostat opened and even running with the cap on but not locked. I could not locate any "bleed" pressure release points on the coolant system. Is there anything I can do?
Jesse
TN
Oct 1, 2009 at 7:07 AM
HMAC300
  • 48,601 POSTS
fill your bottle to a little above the hot level. Install a new radiator cap as these go bad often. Drive it for a couple of days and see if your level goes down a little. That will work the air out of the system. Also you can buy a product for slight overheats. I forget what they call it at the moment.
auto parts store carry it.
Oct 2, 2009 at 11:54 AM
JESSE.TYLER.24
  • 6 POSTS
I will give it a try.
Oct 5, 2009 at 12:47 AM
