2003 Chevy S-10 low side a/c port
JTROUT
Air Conditioning problem
2003 Chevy S-10 4 cyl Two Wheel Drive Manual
Where is the low side a/c port located? Is it the small line with a hook up to it, or the hook up point on the large cylinder?
thanks,
Josh
May 19, 2008 at 10:11 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:c783eca842="Jtrout"]Air Conditioning problem
thanks,
Josh[/quote:c783eca842]
If you purchased a charging kit from a parts store, the connection will only fit the low side. If not the smaller port is the low side.
May 20, 2008 at 5:06 AM
