2003 Chevy S-10 hesitates on cold
2003 CHEVROLET S-10
66,000 MILES • 6 CYL • 4WD • AUTOMATIC
HOTSHOE2J
on first sart in the morning my engine stubles at part throttle, after it heats up, it runs fine. I have replaced the plugs, wires cap and rotor. fuel pressure regulator and throttle position sensor. Im not getting any codes when I scan it.
May 18, 2010 at 5:35 PM
  • CAR REPAIR CONTRIBUTOR
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 19, 2010 at 1:04 AM
