2003 Chevy S-10 fuel problems
63,000 MILES • 6 CYL • 4WD • AUTOMATIC
JASONRAHN1979
2003 s10 crew cab will not take gas at the pump. I am lucky to get a gallon of gas. It comes right back up the filler neck. When i take the gas cap off all you cap here is it venting I looked for a vent tube did not see one every hose ran the the evap is that the problem maybe? Thanks
Jul 23, 2008 at 12:57 PM
JDL
  • 16,098 POSTS
I saw a bulletin on something like this.
Bulletin# 03-06-04-058
Gas spits backup the filler neck when trying to fill.
Cure, replace fuel tank filler pipe, P/N 15124302.
Jul 24, 2008 at 5:28 AM
