2003 Chevy S-10 Engine Light
BASSDUDE_99
2003 Chevy S-10 6 cyl Four Wheel Drive Automatic
Code 0442 Evaporatinv Emission System Control Leak small
Dec 11, 2008 at 10:19 AM
  • 75,988 POSTS
A code P0442 most likely means one or more of the following has happened:
A loose or improperly affixed gas cap
A non-conforming gas cap (i.e. not factory/original brand)
A small leak/hole in a fuel vapor hose/tube
Other small leak in EVAP system
Faulty vent o-ring seal
Possible Solutions With a P0442, the most common repair is to:
Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
Otherwise, replace the gas cap, or
Inspect the EVAP system for cuts/holes in tubes/hoses
Dec 11, 2008 at 11:01 AM
