2003 Chevy S-10 changing a u joint
162,000 MILES • 4 CYL • 2WD • AUTOMATIC
KMIG
  • 11 POSTS
HOW CAN I CHANGE A U JOINT. DO I NEED TO DRILL OUT THE PLASTIC HOLD IN PINS TO PRESS THEM OUT? THEY ARE HARD IN THERE
Mar 15, 2008 at 11:28 AM
BLACKOP555
  • 10,386 POSTS
remove the retaining rings, then get two differnent size sockets and place the small one on the one side then the large on on the other side then put it in a vice and press it out.
or you can buy a tool for it makes it a bit easier.
Mar 15, 2008 at 2:59 PM
