2003 Chevy S-10
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
NICOLTE33
I have a 2003 chevy s10 with a vortec v6 automatic engine and I keep getting a service engine soon light that says its an evap leak its rough and sluggish and after 50 mph it sounds like the engine is over working, i have no idea if these symptoms have anything to do with an evap leak and i dont know what to do
Apr 26, 2010 at 1:29 PM
BMRFIXIT
  • 19,053 POSTS
Fuel leak will cause EVAP codes
Vacuum leak will also cause EVAP codes
Bad gas cap fill do too
Visually check for leaks
And if none found a smoke test is needed
Apr 26, 2010 at 10:50 PM
