2003 Chevy S-10
DIRTYDIME03
  • 14 POSTS
Engine Mechanical problem
2003 Chevy S-10 4 cyl Two Wheel Drive Manual
After trying to diagnose my skipping problem I found out my compression test didn't do so well. I have 180psi on #2,3, and 4 while #1 only has 90 psi, I added oil and it only went up to 100psi. I think it's the head gasket/head or a valve problem any ideas?
Nov 24, 2008 at 1:30 PM
DOCFIXIT
  • 18,828 POSTS
By the results of the wet test a valve is most likely.
Nov 25, 2008 at 8:16 AM
DIRTYDIME03
  • 14 POSTS
Would this make it skip or act like it's skipping at any given point?
Nov 25, 2008 at 12:22 PM
DOCFIXIT
  • 18,828 POSTS
Most certainly will cause a miss. Probably exhaust you did not mention any popping in intake. Hold a cloth on tail pipe it should suck cloth into pipe if exhaust valve burnt.
Nov 26, 2008 at 3:18 AM
