I REPLACED BOTH O2 SENSORS AND NOW IM GETTING A PO155 ERROR. HOW DO I FIX THIS PROBLEM?
Sep 14, 2008 at 2:59 PM
2CARPRO JACK
✓Experienced Mechanic
Should be a fuse for OXYSENS one of the old sensors may have shorted and blown it, should be in the underhood power center. If it is ok, you may need to take it to a shop to be put on a scanner so they can command them to work to see which one is th eproblem
Sep 15, 2008 at 12:46 AM
CHEVY66
MEMBER
Although the fuse looked ok, I replaced it and I haven't got that error. Thank you!
Sep 16, 2008 at 11:39 AM
2CARPRO JACK
Hopefully that was the problem
Sep 17, 2008 at 12:48 AM
