2002 Chevrolet S-10 Hard Cold Start
CMEYERS25
I have a 2002 Chevy S10 2.2 4 Cyl Manual with 26,000 miles on it. When the temperature drops down to around 20 degrees and below it takes almost 10 mins of on and off cranking to get it to start. While cranking as soon as the check engine light clicks on, it will start up and the check engine light goes out. After the vehicle has warmed up it will start up, unless you let it sit for awhile. If it's really cold it will not start at all. The fuel pump is kicking on when you turn the key and the fuel pressure is good. The ECM was swapped out to see if that was the problem, and it didn't fix it. Any ideas would be greatly apprieciated.
Oct 21, 2007 at 4:53 PM
  • 75,988 POSTS
For a start you could check the coolant temperature sensor that's the choke for a fuel injected engine. Might also want to remove the idle air control valve and EGR valve and clean it.
5yrs has passed, when was the last tune-up?
Oct 21, 2007 at 5:03 PM
CMEYERS25
I purchased the truck in 2006, it only had one prior owner and i'm not sure if it has had a tune up.
Oct 21, 2007 at 5:41 PM
  • 75,988 POSTS
The check engine light is it On or has flashed?
Normally a cold starting problems are related to fuel. Lets recheck the fuel pressure with a gauge with and without the regulator
Or do this when it refuses to start check for spark-disconnect a sparkplug wire or 2 ground it to the engine while cranking it over-Do you have spark?
Oct 21, 2007 at 9:35 PM
Suggested Repair
Check the coolant temperature sensor, clean the idle air control and EGR valves, and confirm tune-up history. Recheck fuel pressure with a gauge with and without the regulator, and verify spark during a no-start.
Conversation Summary
A 2002 Chevrolet S-10 2.2 is very hard or impossible to start in temperatures around 20 degrees and below, needing repeated cranking until it fires; it starts normally once warm unless it sits. The fuel pump runs, fuel pressure was reported good, and swapping the ECM did not help. The expert recommended checking the coolant temperature sensor, cleaning the IAC and EGR valves, confirming service history and check-engine-light behavior, retesting fuel pressure with and without the regulator, and checking for spark when it will not start.
