2002 Chevy S-10 Third Brake light
129,000 MILES • 4 CYL • 2WD • MANUAL
MATHACEJR1
Third brake light won't light up, even after putting new light bulbs in. Can you tell me if this could be a fuse or wiring problem? Can you tell me where the fuse is located and/or how to trace the wiring to find a short? I'm not sure what the problem is, doyou have any ideas?
Jan 8, 2010 at 12:18 PM
  • 75,988 POSTS
If the bottom lights works check and test the high mount stop lamp relay
Jan 8, 2010 at 1:10 PM
