2002 Chevy S-10 The lever for the car is stuck and won't sh
2002 CHEVROLET S-10
142,944 MILES • V8 • 4WD • AUTOMATIC
CARTROUBLE71
Yesterday I cleaned out the car and vacuumed for my husband. When I got in the car to go to the store the lever that shifts the car into gears will not shift. It is stuck. My foot is on the brake when I tried to move the lever. It looks like a light goes on and off in the park position. What do I do?
Oct 10, 2010 at 11:58 PM
WRENCHTECH
  • 20,761 POSTS
That would be called the shift interlock feature. It operates on the same circuit as the brake lights so the first thing you want to do is to make sure the brake lights are working when this problem is present. If the brake lights are working, that proves the circuit is good up to that point, then you'll have to get to the solenoid in the console. Disassemble as much as you have to to access the solenoid near the shifting mechanism. Us a 12v test light to test for power coming and going at the solenoid when the brake is applied. If power is arriving and switching and the solenoid is not triggering, the solenoid is bad and will have to be replaced.
Oct 11, 2010 at 1:28 AM
