2002 Chevy S-10 starting
93,000 MILES • 4 CYL • 2WD • MANUAL
GREYGHOST1968
after having a replacement engine installed, the engine will start sometimes, the lights flash on and off, the fuel pump will not work sometimes, the air conditioning works sometimes. I replaced the ignition switch which did not help at all
Jun 14, 2009 at 2:51 PM
SERVICE WRITER
  • 9,123 POSTS
Were these problems present before the engine swap?
Did you pay a shop to do this?
Does the fuel pump energize when the no start is happening?
What lights are flashing on and off and when do the do this?
IS the a/c intermittantly not blowing air? If so what speeds? OR is the a/c intermitantly not cold?
Jun 16, 2009 at 9:55 PM
