2002 Chevy S-10 speedometer
97,500 MILES • 4 CYL • 2WD • MANUAL
JOHNDBAGBY
my speedometer doesn't work,it is analog,code read,speed sensor.had a new one installed.did not solve the problem.had the wiring checked,it was good.What do you think the problem is???
Jan 13, 2010 at 9:17 AM
BLUELIGHTNIN6
  • 16,542 POSTS
may be bad cluster or wiring to cluster. check the circuit board on the instrument cluster, sometimes there will be a bad spot that you can fix with soldering gun.
Jan 15, 2010 at 2:14 PM
