Brake pedal goes to the floor
101,700 MILES • 6 CYL • 4WD • AUTOMATIC
JCSP86
I changed my brake pads tonight and when I depressed the cylinder to allow the new pads to fit over the rotor I forced brake fluid from the reservoir. I have anti-lock brakes and think that when I forced that fluid out I messed the system up because now I can push the pedal to the floor every time I use the brakes. I have braking ability but it's not what I know it should be. Can you tell me how to reset the anti-lock brake system?
Nov 2, 2008 at 2:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You will need to bleed your brake while using a scan tool to open the ABS valves in the control unit. Here is a guide to help you when the scanner is connected.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Aug 27, 2020 at 11:27 AM
JCSP86
That did the trick thanks for the free advice I love this site.
BLUELIGHTNIN6
  • 16,542 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
