2002 Chevy S-10 Replace rear passenger side turn signal bul
2002 CHEVROLET S-10
40,000 MILES • 4 CYL • 2WD • MANUAL
PAT_DACH
How do I get the housing assembly off to change the light bulb?
I did donate $10.
Pat McElroy
Dec 22, 2007 at 4:50 AM
MERLIN2021
  • 17,250 POSTS
Which light?
Dec 22, 2007 at 8:54 AM
MERLIN2021
  • 17,250 POSTS
Inbox :: Message
To: merlin2021
Posted: Sat Dec 22, 2007 7:22 pm
Subject: Re: Rear Passenger Light
You go to the back of my truck, there is a rear passenger tail light and a rear driver's side tail light. The signal that is out is the rear passenger turn signal. How many lights are in the tail light assembly?
This will answer this PM...There are two bulbs in this assy, one for turn and running and the other for brakes...If no nuts are exposed from the bed, then you need to get a T-20 Torx screwdriver or philips and unscrew the lens from the front...
Dec 22, 2007 at 10:27 AM
