2002 Chevy S-10 noise crackling or buzzing in speakers.
61,000 MILES • 6 CYL • 4WD • AUTOMATIC
ROBBIEDEE
does not happen when the radio is on by its self, When i turn the truck on then i get a crackling/ buzzing noise coming through the speakers. On FM station sounds like AM station sometimes. It will go in and out some times , wandering if there would be a short somewhere and how to pin point it. Noise stay the same when the RPM go up. Any help would help. Also what would be a good site to look up recalls. Thank you Robbie
Jan 3, 2008 at 1:10 PM
  • 31,937 POSTS
check power and earths at radio and connections at speakers, fit a radio suppressor to the alternator and coil if conventional coil is fitted. Also a bad earth at the antenna or a poor quality antenna will do this. I don't know about a re call site, for public use, professional sights have access to this information only, contact you dealer they will advise on any re calls as well.
Mark (mhpautos)
Jan 3, 2008 at 1:25 PM
