2002 Chevy S-10 need a diagram of vacuum line
73,000 MILES • 6 CYL • 2WD • AUTOMATIC
DARIODDEAN
if vacuum line is not hook up would it give off air sounds when i pumb the brakes?
May 23, 2010 at 6:06 AM
HMAC300
  • 48,601 POSTS
when applying the brakes it may give off a sound from the vacuum entering the diaphragm. I dont thnk that a sound would be a vacuum leak as one that large would effect the way the truck runs, like idling fast or dropping down when you accelerate. It may be just the normal sound of the diaphragm Or if you have a vacuum pump that may not be working.
May 27, 2010 at 7:53 AM
