My idle will go to 350-400 rpm when shifting into gear or coming to a stop then return to 550-650 and stay there. It basically just dips down then returns to normal.
I have replaced the iac tps maf plugs wires cap and rotor are good new fuel filter changed the vent and purge solenoid checked evap system for leaks Vacume is good fuel pressure is good. Ran top end cleaned through several times had injectors cleaned X2
Took the thing into the dealer they scanned it and got nothing. He reset the computer and it will run good for awhile then start up again with the idle problems.
Jan 20, 2009 at 1:30 PM
