2002 Chevy S-10 head gasket
14,900 MILES • 6 CYL • 2WD • AUTOMATIC
KYLEHOSKISON
i have a blown head gasket in my s10, im not sure which side of the v 6 it is, is there any way to tell? also i plan on doing this project myself, any advice?
Feb 16, 2009 at 5:37 AM
F4I_GUY
  • 3,302 POSTS
You can do a cylinder leakdown test or compression test on every cylinder. A cylinder leakdown test would be the best option since it will tell you where the leak is, but not everybody has an air compressor and a tester at home.
If you want, you can do a compression test and if you see a cylinder that is really low, chances are, that's where the gasket has failed and is leaking compression.
Feb 16, 2009 at 6:35 AM
