2002 Chevy S-10 Fuel pump does not activate and vehicle doe
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAMIROALCALA
Well first of all truck does not start and fuel pump is not running even after replacement. Change fuel filter also and checked fuse box and no signs of bad fuses. Cant figure out why neither the truck nor the fuel pump is not turning on.
Feb 21, 2010 at 11:48 AM
  • 75,988 POSTS
Power the gray wire at the fuel pump connector direct from the battery if it comes On-check and test the ECM B fuse 20amp and fuel pump relay
Feb 21, 2010 at 1:36 PM
