2002 Chevy S-10 Fuel Pump
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
MPARLER
I recently started having problems with my fuel pump not always cycling upon turning on the ignition. I have since replaced the fuel pump and wiring harness to it. I have grounded the pump straight to the frame, replaced the relay and installed a new fly wheel position sensor and yet the fuel pump doesn't always run. I have removed the bed of the truck twice a re-checked all my connections as well as tested to make sure the new fuel pump still works. Any ideas?????
Oct 9, 2010 at 7:49 AM
FACTORYJACK
  • 4,159 POSTS
Are you talking about the 2 second burst it has at key on, before cranking? Is this creating a problem, perhaps an extended crank?
Oct 9, 2010 at 3:26 PM
FACTORYJACK
  • 4,159 POSTS
Thanks for using 2carpros.
Oct 28, 2010 at 4:18 PM
