2002 Chevy S-10 Fuel pump
2002 CHEVROLET S-10
HCAMPBELL1223
Engine Mechanical problem
2002 Chevy S-10 6 cyl Four Wheel Drive Manual
My truck wouldn't start due to not getting any fuel. changed the fuel pump. when you turn the truck on the pump doesn't turn on. check the fuel pump relay & the fuse. truck still does not start. what should i do next?
Jan 22, 2010 at 8:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
need to check wiring to ensure power is getting to the pump. if wiring, relay, fuse and pump are all good then suspect faulty computer
Jan 22, 2010 at 2:20 PM
