2002 Chevy S-10 Fliud issues
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
PATTIZAYAS
I am have a problem with the transmission fluid in my truck. It's disappearing and do not know where. There are no leak spots on the ground. When it goes low it will not shift into higher gear. Please help.
Oct 30, 2010 at 11:10 AM
FACTORYJACK
  • 4,159 POSTS
If there is no external leak, check the cooling system. If it has oil in it, you have a trans cooler that is leaking. It should be noticeable if it has run low enough to cause shifting concerns. Another possibility, if it is four wheel drive, pull the transfer case fill plug with the vehicle on level ground. If it pours out the fill plug, it is overfull, and transmission fluid is passing the input shaft seal in the transfer case.
Oct 30, 2010 at 11:23 AM
PATTIZAYAS
I pulled the top fill plug on the transfer case and alot tranny fluid came out. what is the problem and how do I fix it
Nov 3, 2010 at 5:20 AM
FACTORYJACK
  • 4,159 POSTS
It will require removal of the transfer case, and replacement of the front seal. The minimum parts needed will be a transfer case input shaft seal, adapter gasket, and fluid for the transfer case.
Nov 4, 2010 at 5:09 PM
