the code p0179 keeps coming on, fuel composition sensor circuit high input. I dont know what that is or how to fix it.
Wednesday, September 30th, 2009 AT 1:16 PM
SERVICE WRITER
MECHANIC
Appearently yours has flex-fuel. I have had the same vehicle in with that code & it was the sensor. It is located on the rt frame rail by the back of the wheel opening. Follow the fuel lines down and you will find it. Also called a flex fuel sensor.
