2002 Chevy S-10 diff oil
160,590 MILES • 4 CYL • 2WD • AUTOMATIC
MAGUB
is there a drain plug on the rear axle or do i have to remove pan cover and refit with new gasket? Where is filler plug located and what is the best oil to use shoud i use an additive also? thank you
Nov 10, 2010 at 7:02 AM
JDL
  • 16,098 POSTS
My info says to use 80W90 gear oil in the rear. I'd have to look for drain plug? where applicable, in the picture.
https://images.2carpros.com/forum/automotive_pictures/170934_s10_rear_axle_drain_plug_1.jpg
Nov 10, 2010 at 7:18 AM
