Iwas driving my truck and my clutch just went to the floor. I have not had any problems with this before
Feb 6, 2009 at 2:12 PM
BLUELIGHTNIN6
✓Experienced Mechanic
Does clutch come back up when you let off or does it stay to the floor?
Feb 6, 2009 at 4:01 PM
BUTLERTTT
MEMBER
There is no tension in it . Its just real easy to push it in just happened all at once while i was driving tonight
Feb 6, 2009 at 4:06 PM
BLUELIGHTNIN6
Check the clutch fluid in the master cylinder under hood. Let me know if it is full/empty/burnt smell etc..
Thanks for using 2CarPros.com!
Feb 6, 2009 at 4:26 PM
BUTLERTTT
MEMBER
i checked one place it had a cap on it that said clutch im not sure if this is the master cylinder or not this was like a little hose it was pretty full but looked kinda coroaded
Feb 6, 2009 at 4:33 PM
BLUELIGHTNIN6
Master cylinder is kind of like the brake master cylinder and is usually located beside of the brake master cylinder. The brake master cylinder is where the brake fluid is poured at. The clutch master cylinder is for the clutch fluid. It is a small plastic-like container which holds the extra clutch fluid.
Feb 6, 2009 at 4:43 PM
BUTLERTTT
MEMBER
i checked the resivor it looks like it may need fluid i use brake fluid right
Feb 6, 2009 at 7:12 PM
BLUELIGHTNIN6
yes, brake fluid is correct. let me know how it feels after it is filled and bled.
