2002 Chevy S-10 Changing sparkplugs.
78,000 MILES • 6 CYL • 4WD • AUTOMATIC
T.LEHENY
I Changed all the sparkplugs by taking each tire off.One at a time working through the wheel well.The passenger side was easy.The drivers side changed two then the steering column appears to be in the way.How do I disconnect the column?
May 12, 2008 at 4:45 AM
RHALL77
  • 3,361 POSTS
you shouldnt have to. if you use a swivel socket, you should be able to get at it
May 12, 2008 at 4:52 AM
