2002 Chevy S-10 ABS panel light ON
2002 CHEVROLET S-10
GREGFURMANOS
Brakes problem
2002 Chevy S-10 6 cyl Four Wheel Drive Automatic 130K miles
The ABS light comes on after driving over ten miles when brakes are applied & a flash red brake light.
Only comes on when pedal is pressed & when key is turned OFF & on again, light goes out. Codes; stop light switch, RS sensor, LS sensor, Rear sensor.
All these codes show. It also effects speedometer & that in turn effects transmission.
What could be the problem without buying the sensors as they run + $ 300 w/ hub pack. Not sold separetly.
ABS
Greg
Sep 28, 2009 at 5:32 AM
HMAC300
  • 48,601 POSTS
take it to a pro mechanic that can read the problem as it may be a bad battery or shorted wire. You also may have another brake problem.
Oct 2, 2009 at 12:04 PM
