Brakes problem
2002 Chevy S-10 6 cyl Four Wheel Drive Automatic 130K miles
The ABS light comes on after driving over ten miles when brakes are applied & a flash red brake light.
Only comes on when pedal is pressed & when key is turned OFF & on again, light goes out. Codes; stop light switch, RS sensor, LS sensor, Rear sensor.
All these codes show. It also effects speedometer & that in turn effects transmission.
What could be the problem without buying the sensors as they run + $ 300 w/ hub pack. Not sold separetly.
ABS
Greg
ABS
Greg
Sep 28, 2009 at 5:32 AM
