changed front brakes and my abs comes on about 1 week later and has not turned off.
Oct 28, 2009 at 3:49 PM
✓Experienced Mechanic
There are sensors behind the backing plate. Check to see if you by accident disconnected one while working on the vehicle or lifting it.
Also, if everything looks good, take it to a nationally recognized parts store and have them scan the computer for codes. At least then you will know where the problem is coming from.
