2002 Chevy S-10
FORDTECH34
Engine Performance problem
2002 Chevy S-10 6 cyl Four Wheel Drive Automatic
vehicle will not start unless accelerator feathered will not idle at first with out feathering pedal after a bit will idle on own but when put into gear stalls
Sep 19, 2010 at 5:22 AM
HMAC300
  • 48,601 POSTS
check your fuel pressure after you change your fuel filter. if your service light is on have your engine scanned to find the code. then get some choke cleaner and spray your throttle plate on both sides as well as the oblong hole to get teh oily stuff off of it.
Sep 19, 2010 at 1:13 PM
