2002 Chevy S-10
KEN MCDUFFIE
Air Conditioning problem
2002 Chevy S-10
how do i repair the a/c cluch inside of the a/c unit?
Jul 13, 2010 at 10:04 AM
HMAC300
  • 48,601 POSTS
it could be low on freon that is causing this. the only way to check is to have a set of gauges hooked up on it. but if you want to do it, you need a puller and installer for it. there is a nut in the center and a large snap ring to get to the coil that operates the clutch....
Jul 13, 2010 at 12:51 PM
