2002 Chevy S-10
165,565 MILES • 4 CYL • 2WD • AUTOMATIC
BENJI2213
MY ABS Light is on and sometimes off.Is there wheel sensors to change or what do I do?
Mar 14, 2010 at 12:04 AM
HMAC300
  • 48,601 POSTS
get it scanned to see where the problem lies. It can be a sensor, a bad wire, etc. Or the abs unit itself.
Mar 15, 2010 at 5:08 AM
BENJI2213
I have a OBS 11 scanner and no codes come up. Auto zone told me the sensor is in with the front wheel bearing. I looked at several in the junk yard and can't even find any wires?/
Mar 15, 2010 at 7:10 AM
HMAC300
  • 48,601 POSTS
i fyou have one of the scanners fro auto zone they wll not read abs codes. Only engine codes. Ifyou have one ofthe exspensive ones then it should read codes. The sensor will not always be in with the wheel bearing either. It can be in the spindle and there should be a fine wire harness leading to it. It should come from the fender well area
Mar 15, 2010 at 12:18 PM
