2002 Chevy S-10
106,000 MILES • 6 CYL • 4WD • AUTOMATIC
BLPURSELL
When the heat is on and the truck is idling it blows cold air. The temp. gage stays where it should be (195 deg.) When the truck is at 1500rpm or more hot air then comes out. Is this a vaccuum problem and where do I start?
Jan 29, 2010 at 12:05 AM
  • 110,251 POSTS
Make sure the coolant level is full. Let me know what you find.
Feb 3, 2010 at 12:29 AM
BLPURSELL
It is a used truck I just purchased and had been sitting awhile. I drove the truck hard for one day and now everything seems to be working properly. Not sure what was wrong.
Feb 3, 2010 at 12:37 AM
  • 110,251 POSTS
It may have needed cleaned out / old fuel...
Feb 3, 2010 at 2:21 AM
BLPURSELL
OK Thank you for your help
Feb 3, 2010 at 5:28 AM
