2002 Chevy S-10
MICHAEL61
Engine Mechanical problem
2002 Chevy S-10 6 cyl Two Wheel Drive Manual
We have a 2002 chevy s-10 pick up. The engine will turn over, and we have good spark but the engine will not start. Could the fuel pump be bad?
Dec 19, 2008 at 11:23 AM
BLACKOP555
  • 10,386 POSTS
coudl be a bad fuel pump.
beofre you go and replace it buy or rent a fuel pressure check guage and see what your getting for pressure.
if its good then check for injector pulse. if bad replace the fuel filter, and if still no good replace the pump assuming its turning on.
Dec 28, 2008 at 10:15 AM
