2002 Chevy S-10
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
POKER3
engine runs 5 seconds to 10 min's , when it stops runing it does not slow rpm it is as if the key was turned off . all lights stay on blower motor stays on.i have replaced the igniton module. and the fuel pump ,fuel ingectors were replaced last summer any thoughts
poker3
Jan 18, 2009 at 11:24 PM
JDL
  • 16,098 POSTS
After it stalls, does it restart right away? If it doesn't, you can do some basic tests, like checking for spark at the plugs.
Can you check for troublecodes? When it stalls, is the theft lite flashing, where applicable?
My first thought was, you might be losing the rpm signal?
Jan 19, 2009 at 12:32 AM
