2001 Chevy S-10 White smoke, shaky
2001 CHEVROLET S-10
SLOOPALESCI
Engine Mechanical problem
2001 Chevy S-10 4 cyl Two Wheel Drive Manual 110k miles
Sometimes when I start my chevy s10 it will sound and feel like it has a really low idle and it will blow a lot of white smoke. I recently had my radiator replaced because it was cracked. From my research it sounds like coolant in the cylinders. My engine did get hot but I never let it get hotter than 250 degrees. Ideas? :(
May 5, 2009 at 11:03 AM
BMRFIXIT
  • 19,053 POSTS
Suspect Headgasket and or intake manifold gasket
for the coolant to enter the cylinder
Have to do coolant pressure test and headgasket test
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 5, 2009 at 11:24 AM
