2001 Chevy S-10 turn signal and brake light out
2001 CHEVROLET S-10
116,000 MILES • 4 CYL • 2WD • AUTOMATIC
NMMEYERS
The tail light on my s-10 works but the brake light and turn signal on my rear left side still do not work. So it's not a ground problem. I checked the fuses under the the hood and the fuse is not blown. I tested the fuse housing with an electrical tester while I had the signal on and still did not get a reading. My problem is somewhere between the fuse box and the relay signal itself. What are all the possibilities that it could be?
Dec 27, 2008 at 2:13 AM
JMICHAEL8888
  • 45 POSTS
i believe that fuse is always hot and is connected to your headlight switch. i would check for voltage at the yellow wire i believe for a pulsing 12 volts with the blinker switch activated. if there is volts replace the taillight assembly.
Dec 29, 2008 at 1:39 PM
