2001 Chevy S-10 Trouble codes
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
THALICTRUM
Recently had the gas tank and fuel pump replaced. Plugs, wires, cap are not that old. Went for an inspection and failed with these trouble codes:
P0128--seems to be reocuring--already replaced the coolant temp sensor once.
P0155
P0300
I do need to replace the gas tank filler neck valve as it may be leaking but not positive. Would a leak cause the above 02 sensor codes to happen? Not sure if I should start by replacing the o2 sensors or start by replacing the filler neck valve.
Mar 20, 2009 at 10:43 AM
MASTERTECHTIM
  • 4,750 POSTS
filler neck wont cause o2 sensor codes. did you replace thermostqt for coolant sensor problem, im finding thats the problem
Mar 20, 2009 at 11:06 AM
THALICTRUM
I replaced the coolant temp sensor a while back. The P 0128 code came back on about 6 months later.
Mar 20, 2009 at 11:09 AM
MASTERTECHTIM
  • 4,750 POSTS
recheck coolant temp sensor and replace again if needed, also check wiring connector to make sure its good and tight
Mar 23, 2009 at 1:06 AM
THALICTRUM
Replaced the thermostat and the pre cat O2 sensor. Every thing seems fine now...no codes. Thanks. Where is your shop in Boston? I also live there.
Mar 23, 2009 at 1:25 AM
MASTERTECHTIM
  • 4,750 POSTS
holbrook. jt auto on 400 south franklin st.
Mar 23, 2009 at 7:30 AM
