2001 Chevy S-10 trans wont go into drive
2001 CHEVROLET S-10
SNOOPY48
Transmission problem
2001 Chevy S-10 4 cyl Two Wheel Drive Automatic
I do have reverse , but do not have drive or 3rd gear , you can shift it to 1st and 2nd an be able to take off once you get goin you can shift it to 3rd then drive but once you stop you have to put gear selector in 1st or 2nd to start again when driving it it would down shift to pass and then shift up but tryed it again and it was like you put it in neutral you could shift back to second and go again . any thoughts on what is going on- have checked fluid it is fine and smells fine all elect connections are hooked up.
Nov 21, 2009 at 7:29 PM
You have an internal problems within the transmission to find out more get it pressure tested.
Nov 22, 2009 at 5:54 AM
