2001 Chevy S-10 starting
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
LUISIBARRA123456789
yes i have a 2001 chevy s 10 pickup . ive replaced the fuel pump spider injector.the problem is that if it sits a while it wont start then all of sudden it will. my fuel pressure with the key on is 64 and when the pump stops operating it will drop to 54 and hold.
Sep 14, 2008 at 1:28 PM
KEVIN12881
  • 336 POSTS
the starter is turning right? is it turning strong or weak? do you only have problems when it is hot? are you do for a tune-up? Try cleaning air filter, bad engine ground connection, loose conection in ignition system, change fuel filter
Sep 14, 2008 at 1:35 PM
