2001 Chevy S-10 Spurts and dies on acceleration on takeoff
2001 CHEVROLET S-10
270,000 MILES • 6 CYL • 4WD • MANUAL
JWCHEVY
My S-10 on the way home died 2 times on the way home today , engine cut out at the light as I was accelerating off the line. Got home barely replaced some fuses tried giving it gas in neutral seems fine. Tested to see what happend when I moved and it died again. Fired it back up and pulled back into my parking stall. So I dont think that its the fuel pump because in neutral its getting gas and the rpm's are moving normal but for some reason when I engage the Clutch it dies. Its a fairly new clutch aswell less then 50,000 on it. Distributor maybe ? or that clutch sensor thing by the pedal maybe I dont know? Anyways any advice or help you can offer would be awesome.
Oct 29, 2009 at 10:39 AM
  • 110,244 POSTS
The clutch safety switch doesn't do anything after the car is started. Has the check engine light come on? Have you checked fuel pump pressure? Have you checked for vacuum leaks?
Nov 12, 2009 at 2:43 AM
