Tuesday, June 8th, 2010 AT 8:18 PM
This thing is racking my brain. It works for a while, then the truck just cuts off. Nothing. After a while I can try it again and it works normally. I'm leaning toward the fuel pump, so I removed the bed from the truck and turned the key and I heard the fuel pump come on. And when it doesn't come on and I can not hear it humm right before I try to start, it won't start. Anyway I took a test light and checked the power at the pump making sure connections and the ground was ok. On the two wire plug, one wire had what appeared to be full voltage (12V) when I tagged the other wire the test light lit up about halfway, maybe 6V or so. Is that normal? Thanks for any help.
